suggestions and ideas for step and preset modules
cybercharles
Unread post by cybercharles » 07 Jul 2008, 12:07
Hi Olivier,
some suggestions and ideas to improve the software:
1/ Creating a preset manager for each module and not for the entire patch. For example, to have a preset manager module (like the actual module) but you can link it to any other particular module with a new input named “preset”.
2/ It would be useful for both step and step MIDI modules to:
- be able to save the sequences in external files like in the piano roll module
- loading this files by clicking on module (like wave files in sampler) with a reading mode feature (next, prev, random)
- to have a switch to reset the sequence in one click
3/ Creating a new step MIDI module with both velocity and notes in two parallel sequences (with the same features than before…).
4 /Never stop to develop this wonderful software !!!!!
Charles.
t
Unread post by senso » 07 Jul 2008, 12:42
not so easy in the general case because most of modules don't have any value to store in preset.
good suggestions and probably easy to implement except for the next prev, random options...
more generally a way to improve the modularity of usine, be able to create 'packets' of linked modules and load them in a patch.
don't worry ...
Users browsing this forum: No registered users and 102 guests
