synchronise piano roll with sample player
joffo78
Unread post by joffo78 » 23 Dec 2015, 09:52
Hello.
I try to synchronise a piano roll with a sampler.
what i would like to do exactly is writting a score on a piano roll to trig events in relation with music on a sampler.
Using marker is not a solution because i need a lot of differents event
i can't using only triggering to synchronise there because i need to move position everytime.
If someone have an idea.
Thanks.
JF
P.S: Is it possible to display piano roll in transparency with the sampler ?
Unread post by senso » 29 Dec 2015, 12:30
cut your sample into small parts and
use the midisampler http://www.sensomusic.org/wiki3/doku.ph ... di_sampler ?
it gives 128 triggers possibles. Each note will trig a sample.
senso+++
joffo78
Unread post by joffo78 » 30 Dec 2015, 00:22
in fact i did the contrary. i play a sample on the grid and trig a little pieces of midi files with several piano roll on different racks ;)
Users browsing this forum: No registered users and 376 guests
