fx bus
seamus
Unread post by seamus » 04 Oct 2012, 00:12
I was curious how people have there fx's setup.
All my instruments feed one fx bus. Ideally i would like to have a couple more with some kind of switcher so that i can route the audio through different busses. (there are loads of good vst plug fx's!)
Each bypassed vst still adds latency to the overall signal correct?
I feel that one bus with a few vst's is ok latency. I dont notice it so much.
I imagine if i hardwired bus a into b then bus b into c i would notice more latency even if they were bypassed.
SO it seems like some kind of switching matrix would be cool to use.
seamus
Unread post by seamus » 04 Oct 2012, 08:51
seems like the matrix audio module may be what im looking for. I will try it out now. I hope that the routings can be stored with the conductor.
Unread post by nay-seven » 04 Oct 2012, 08:59
And as an alternative, you can also check the last add-on of Joffo :
check here
seamus
Unread post by seamus » 05 Oct 2012, 17:11
http://www.sensomusic.com/forums/viewtopic.php?id=3535
joffo's workspace seems a great example of what i was sort of aiming at.
thanks NAy
joffo78
Unread post by joffo78 » 05 Oct 2012, 22:00
Very proud that my patch could help you
Unread post by woodslanding » 21 Oct 2012, 22:42
I have four fx set up (using usine's FX busses) that can feed into each other. Also, I have my sends set up so that 0=dry .5 = 50%wet 1=100%wet. Easy to do with usine, and you don't need a pre/post-fader switch. Each instrument only goes to one of the four FX, but each effect can go into another.
I set everything up so I can dial up sounds really quick from a one-page interface, so that is my thinking. I started out wanting more busses, but usine's internal busses seem to be more CPU efficient (important when you are running 20+ vsts!)
One of my FX is an instance of Zen, which can load presets from different VSTs, and stores them all in a common bank. It works, but it is a little buggy. It doesn't like certain vsts, and usine doesn't like certain ones too, so it's a bit of a challenge. The other three are a custom delay built in reaktor, ReverberateLE (with a lot of crazy 3rd party impulses) and guitar rig. So that gives me quite a lot of sonic flexibility.
Users browsing this forum: No registered users and 293 guests
