Monitor Out
normally it still appears in the setup/audio out !
tested on my systems.
so?
so?
It is a bad news because it doesn't appear on my system !!!!
I tried to change my screen resolution, but nothing change in Usine, no monitor out !!!
:O
interesting!
did you change the default police size of windows?
or the titlebar height?
No i didn't tried but i have been trying now, and nothing changes ...
My police size is normal and my title bar height is 31 (my resolution is 1680 x 1050). But it is the same with a smaller title bar height or an other screen resolution !
In the 3.68 version of usine there is no problem, but since the 4.0 beta this problem appear ....
Before to find a solution, is there a way to configure the 'Monitor Out' manually ? In the setting.ini file ? ...
Christophe
Christophe
manualy
open the Default-settings.ini
find the line
INDEXheadphone out = ...
set INDEXheadphone out = -1 for no monitoring,
set INDEXheadphone out = 0 for monitoring as out1,
set INDEXheadphone out = 1 for monitoring as out2,
etc...
but you can try to restore the default settings of the windows desktop?
I'll post updates soon.
find the line
etc...
Thank you Olivier, you are a master !!! i have change setting in the 'default-setting.ini' file and now i can use my Headphone Monitoring, even if it doesn't appear in the Audio OUT setting of usine so far.
You are great because i will work with Usine next week and i want tu use the new 4.01 version.
Thank you very much
Christophe.
Thank you very much
Christophe.
Thank you Olivier for the 4.01a but it doesn't solve the problem of the 'Monitor OUT' Setup on my computer ...
I am sorry :/
I am sorry :/
@cmodica: did you try to reset your default desktop?
for example the basic xp theme?
your current proportions doesn't look 'normal'?
hep!!!!
you are looking in the audio-in tab!!!
the monitor selector is in the audio-out.
Sorry Olivier, you are right !!! Monitor Out is ok in the 4.01a, but of course in the Audio Out tab !!!! :rolleyes:
I was tired yesterday when i tried it.
sorry and thank you very much,
you are the best.
you are the best.
no pb!
Users browsing this forum: Bing [Bot] and 177 guests
