VST Export: Best practices?
TFF
Unread post by TFF » 17 Aug 2011, 23:33
Aside from the things outlined in the wiki, are there any guidelines you should follow to get the best performance from exported VSTs?
Also: is there a way to reduce the number of parameters the VST is exported with? All the ones I export list 256 parameters, even if only the first three or four are used.
-Zach
Unread post by nay-seven » 18 Aug 2011, 10:30
The save as Vst is an option too recent to have a good view of the good practices, but a good and the more simplest possible conception is the first answer.
actually, you can't change the parameters number, could be maybe improved in the future.
Users browsing this forum: No registered users and 580 guests
