Updating conductor presets with program change
La Tenaille
Unread post by La Tenaille » 10 Sep 2008, 10:29
Is it possible?
amiga909
Unread post by amiga909 » 10 Sep 2008, 11:41
surely possible.
I guess u tried to apply a midi learn to the conductors '0'- '20' buttons?
alternatively do it in the global remote menu.
if this does not work:
a magnificient feature of usine is that you have almost every control unit also as a module, gives you TOTAL control :)
select the conductor from the interface control modules. manual says for the scene number input pin: "Current scene number. Can be used for direct recall of a scene with a MIDI CC or PC."
La Tenaille
Unread post by La Tenaille » 10 Sep 2008, 12:18
I just tried on a bypass button to see what happens. The log window says "Learn midi: 240 0" regardless of the PC number, and nothing happens.
Usine catches a SYSEX change and don't make the difference between the numbers...
I've dragged the interface control module in an empty patch, I see its num input pin, but I don't know how to "manualy talk to her" :D
I'm quite sure my pedal board sends PCs: I've plugged it to a hardware multi-effect and it works, the presets are updated.
Users browsing this forum: No registered users and 849 guests
