How to turn your pc into a touch-screen pc?
Unread post by senso » 03 Sep 2008, 13:04
You don't need to buy an expensive Tablet-PC, just add a touch screen layer to your actual monitor.
You will find lots of references on the net for cheap (generally less than 75€), also for your portable PC.
For example
http://www.magictouch.com/
http://www.touchscreens.com/intro-anatomy.html
http://www.nemacom.co.uk/touch_screen_m ... een%20Kits
I'll try to complete the list soon.
Personnally I have a Clevo Tablet PC
http://www.clevo.com.tw/en/products/pro ... oductid=85
One of the cheapest, and highly customizable.
multiphone
Unread post by multiphone » 03 Sep 2008, 18:28
just the question I want to ask...
Ok.
One hand for the wii mote, the another for the touch screen layer, the foots for pedal.
Wahooo !!!
Very nice job.
HB
Lines / Points / Squares
http://www.hervebirolini.com/
amiga909
Unread post by amiga909 » 04 Sep 2008, 11:38
yuppie :)
thanks for the tip, mr. senso
not sure if a mountable touch screen layer would be a solution for me, cause I have a rackmount desktop pc, no laptop. currently I take a 19' monitor with me (not cool)
for me: if I have a touchscreen I want high quality, the models I tried so far (<500$) did not suffice. albeit I have among other behringer controllers I believe money should not be saved for controller hardware, rather for plugins (and go to gersic.com).
some models:
guess I want 17' at least.
-> Clevo Tablet PC: too small for my taste, kewl is portability
-> touchscreen monitors: LG Flatron L1730SF 17' for ~600$, and the iiyama ProLite T1930SR-1 19' for ~750$. maybe too cheap
-> pen tablets: not sure if working with a pen instead of fingers is nice. looks more expensive...
Wacom Pen Display PL-720, 17": ~1700$
Belinea s.display 5, 22", Pen Tablet, ~1700$
--> found no transportable touch screen monitor?
--> go for a normal monitor and follow senso's recommendation?
--> do you think it makes sense to wait for multitouch monitors?
lemurs exclusitiviy seems to fade away..apple is going hard to bring it to the mass market. maybe 1 year to wait for a 700$, 17' multitouch device?
moljen
Unread post by moljen » 05 Sep 2008, 09:41
I've bought and installed touchscreen overlays from http://www.hometouchsystems.com/
They're in the UK and are quite cheap... though the install is quite DIY.
Looking forward to the new Using TouchScreen Version.
stanlea
Unread post by stanlea » 05 Sep 2008, 18:18
Doas this mean that I can use my Wacom tablet with a pen to control Usine ?
You know my name (look up the number)
Unread post by senso » 05 Sep 2008, 18:21
stanlea wrote:Doas this mean that I can use my Wacom tablet with a pen to control Usine ?
yes of course.
Also, the tablet pc mode works with a 'normal' mouse!
stanlea
Unread post by stanlea » 05 Sep 2008, 18:27
Coooooooooooooooooooooooool !!!!!!
amiga909
Unread post by amiga909 » 08 Sep 2008, 01:56
googled about the topic a bit further
SOS tested a intatouch DIY touchscreen kit here:
http://www.soundonsound.com/sos/mar06/a ... ?print=yes
interesting: " you really need to be looking straight at the screen: because there's a gap between the touch screen and the LCD beneath, the two appear slightly out of alignment if viewed at an angle"
-> could hold for other models too.. would make live use sloppier..
http://www.youtube.com/watch?v=Mz-vN8XvXpM
shows a transportable touch screen. if this is cheap, thats the kind of thing I'd like to get! any ideas?
http://www.youtube.com/watch?v=_gezANCT ... re=related
another way... multitouch for <20$ (webcam + video tracing software)..well nothing live gig proofed I guess ;)
anybody knows the LG Flatron L1730SF 17'? read it can be mounted on a wall like a picture. this thing could do the trick for me then, as said around 550-600$, reaction time ~12ms...
Clearscreen
Unread post by Clearscreen » 08 Sep 2008, 08:51
personally i'm thinking about getting one of these:
http://www.lilliputweb.net/ts859.html
gets vga output and touch from a usb port. not as cheap as the other options but cheaper than a big touchscreen...
seamus
Unread post by seamus » 27 Mar 2012, 19:55
has anyone turned their bootcamp macbook pro screen into a touchscreen monitor?
That would be cool!
microsoft and apple in bed together!
Unread post by 23fx23 » 27 Mar 2012, 20:41
@ seamus yeah that's doable, last year i had a mbp 15' running bootcamp with a cheap overlay from ebay. it was cool for a while but resistive needed to high pressure and started to behave weirdly with time, so i wouldn't recommand resistive panels, but optical ones must be cool.
seamus
Unread post by seamus » 29 Mar 2012, 17:53
Optical overlay for Macbook Pro
I will see if I can find anything like that.
Users browsing this forum: No registered users and 229 guests
