VAC & Usine
Vincent
Unread post by Vincent » 01 Sep 2008, 17:04
Did I miss something?
Virtual Audio Cable(s) dont appear in Usine's audio setup, since they appear (and work) in the setup of all my other apps.
Tanks for advices!
vincent michel
composer & novelist
Unread post by senso » 01 Sep 2008, 17:16
VAC is an ASIO driver?
Vincent
Unread post by Vincent » 01 Sep 2008, 23:26
Of course, that was the good question. Thanks, Olivier.
Answer of VAC itself: "VAC has a Windows virtual WDM/KS device driver"
So, have you heard about any other kind of Virtual Audio Cable that has an ASIO driver?
Or, and this should be asked in the 'suggestion forums', could Usine easily do that?
vincent michel
composer & novelist
Unread post by bsork » 02 Sep 2008, 07:56
Hi Vincent, I've tried Jack for Windows which can pose as an ASIO driver almost with success...
Had a hard time setting it up and get to it work, but screen updates and mouse movements created far too much clicks to be acceptable, but you may be more lucky? Read this thread on KVR: http://www.kvraudio.com/forum/viewtopic.php?t=211463.
Vincent
Unread post by Vincent » 05 Sep 2008, 00:41
Great thanks bsok!
I'll srr that with much interest!
vincent michel
composer & novelist
Users browsing this forum: No registered users and 374 guests
