I'm trying to bypass the insert patch when a patch is playing in the Seq.
I've tried to create a midi message on activation of this patch. I'm sending this message through a midi bus...It seems to be sent, but the insert patch does not receive anything in the midi bus. I also tried to use the patch remote for the insert patch, and i'm not able to use it, midi or key learn does not seem to work. What am i doing wrong?
Seq and insert track bypass
- senso
key learns don't work on insert patches.
They are so many patches locations in usine that it can take a long time to handle midi learns. So I have limited the possibilities.
but the midi bus should receive midi codes.
I'll take a look.
I'll take a look.
