Hello Olivier,
When I modify a patch in the grid view, it's not updated in the sequencer/live view.
Do you think it'd be possible to implement a kind of "update all patches" button to avoid deleting the modified patches and dragging them again in the sequencer to update them?
I imagine real time patch update from grid to live view would make the system being unstable?
Jacques
A simple way to update patches in the live view?
- senso
Actually, the only way is to save your patch in the grid and make a 'reload' [ctrl R] in the patch of the sequencer; then, you avoid a new 'drag and drop'
an 'Update all patches' can be a good idea but seems to be dangerous in the general case?
La Tenaille
Well, I didn't know the reload function. Seems to be enough for my use.
Thanks for the tip!
Thanks for the tip!
