I'd like to bypass patches or VSTs with my midi pedal board. The trouble is I have a crackle when I activate or deactivate the bypass patch button . The same happens with the VST built-in bypass button, or even with the usine built-in FX...
It happens with my midi controller, but also with the mouse or keyboard remote.
The crackle is terribly amplificated with a VST reverb suddenly switched on for example...
Do you have a solution?
Crackle when bypassing a VST plugin...
- nay-seven
hello
i know that senso work on an update for graphics problems , for example i've crackle and noises when i move modules and when i 'm after 50% of cpu
maybe it's the same one and next version could solve this...
waiting for this you could also try a patch i've made here :
http://www.sensomusic.com/download.php? ... in_out.pat
it's fade on/off audio smothly ...maybe..
and i also want to say congrats and chapo bas for your work , just have see your video of celestroi
it's...amazing , cool , fresh , thanks for the dreams and children
- senso
yes nay-seven, I'm working on a new graphic engine more powerful and less glitches with hi-cpu load.
La Tenaille
Thanks for the link nay-seven, I'll try it soon. I had already thought about a smoother on the main VST level effect... and thanks for the feedback about our work, I always appreciate feedbacks... when it's not in my stage wedge
