Hi All!
I posted earlier in an other thread about midi sync... got answers, experimented, now I'm back!
I'm still in test mode, looking to have a couple of things working before I buy a license of this amazing software.
so, I tried syncing usine with midi clock in both master and slave mode, with many question marks in both tests.
when in slave, using Receive Midi Clock I or II, my problem is that I cannot get the start beat in a mesure on my external sequencer to coincide with the start of the loop recorder for example, also I have not figured yet what to do with the start/stop/continue my sequencer sends.
then, when in master, my sequencer gets the right start and stop from usine, but its not sync with usine tempo... ??, don't know what to think about this one, but I tested my sequencer with some other software inside my PC and it syncs correctly. inside usine I use the 'send midi clock' patch on a track to send the midi clock and it seems like the patch is not synced with usines internal tempo. What am I missing over here?
thanks!
L-P
midi sync
the midiclock sync under Usine is made with a patch which can be improved.
I know that actually there are still some troubles.
I'm working on this pb and try to solve it (definitively...)
just a matter of weeks now...
ok, thanks,
I'll wait for an update before I dig further into midi clock
L-P
L-P
Users browsing this forum: No registered users and 229 guests
