It seems that we can't put more than one Seq midi module per patch in Seq mode...Each time i've got an error about the Buffer Switch Time Info.
Is this normal or a small bug?
Any way, there is a work around with the piano roll module but worklfow is better with the seq midi module...or to explode on different tracks a patch with more than one vsti.
Seq midi module
you are right, unfortunately you can't have more the one seq midi module in a patch. This module is linked to the graphic display in the time line and with 2 of them you may have conflicts.
of course the error msg isn't normal!
I'll check it.
I'll check it.
Users browsing this forum: No registered users and 282 guests
