new version [3.68b] VST package problem
Announcements
Unread post by senso » 11 Jul 2008, 23:27
[3.68b] 08/07/11
A couple of last minute updates. Concerns especially the VST version which was built with an older version of Usine...
For the rest, you can skip this update if everything rocks on your system.
improvements
- re-sizable preset panels
- snap to grid for containers
fixed bugs
- CC curves 4,5,6,7,8 don't work in the pianoroll
- the filter panel is not updated in the interface builder
- the vst version package. The 3.68a was built with an older version of Usine VST...
[3.68a] 08/07/10
Major improvement
new modules
- data and audio Mixers
- Nintendo Wii remote manager
- draw points curve
improvements
- draw a CC curve directly in the pianoRoll
- load up to 16 Midifiles in the pianoRoll
- new zoom button in Step, XY, Oscilloscope panels
- new preset panel design
- easier object selection in the Interface builder
- the minimum delay value in the delay module is now 0 ms
- new 'start on activation' option in the sampler module to enable/disable the
re-starting from the beginning on the activation of the patch (only in loop mode)
fixed bugs
- solo button in the InterfaceControl/MixerOutput module can crash Usine
- when double-click on a slider the edit field appears on the up-left corner of the interface builder.
- after rename a slider the inlet isn't updated in the patch
- midi notes in the 'fader midi notes' module are displayed an octave too high.
- Better compatibility with VST plugs (CSR, T-Racks etc.)
- the size of the containers in the interface builder changes when lock/unlock
- strange behavior of containers when the grid size of the interface builder = 1
- the width of the remote panel is too large on 1024x768 screens
runagate
Unread post by runagate » 12 Jul 2008, 21:53
amazing
I don't know how you do it
I might have to start trying to dream up feature requests finally just to see what else you can do well
Users browsing this forum: No registered users and 153 guests
