a Bus Window
Vincent
Unread post by Vincent » 11 Jul 2008, 00:19
Hi Olivier.
I'm talking about a window in which you could see all your audio/data/midi (I/O) busses listed, with their location (name of the parent patch and track#), their status and a "find in patch" button. Some kind of matrix would be a dream.
Could be very usefull to retreave one's way in complex routings!
Thanks.
vincent michel
composer & novelist
Unread post by senso » 11 Jul 2008, 08:18
good suggestion. As fast as possible....
Vincent
Unread post by Vincent » 11 Jul 2008, 15:25
Thanks Olivier, take it easy!
vincent michel
composer & novelist
Unread post by senso » 11 Jul 2008, 15:57
my TODO list is very long...
Vincent
Unread post by Vincent » 11 Jul 2008, 16:03
I can figure it.
Be sure not to be slave of it. I mean: be slave of nothing!
vincent michel
composer & novelist
