On request from Moody33 (see http://www.sensomusic.com/forums/viewtopic.php?id=922), I've created a patch that saves changes in input data to a text file. It's designed to be used as a sub-patch.
I haven't tested the patch with a lot of data being created, so beware if that "write" switch is on for a looong time, especially if your tracking rapidly changing float values.
The patch is "data tools/Data2TextFile.pat" in the add-ons section.
(Changed) Data To Text File patch
yes ! yes!
impatient to have the Textfile to data patch!
Coooooooool !
It works fine !
Thanks you. Really.
It works fine !
Thanks you. Really.
