Hi Senso, I love the new add ons, they're just what i've been looking for, and they mean i can now begin to properly start using usine live, HOWEVER, your synced bar recorder has a button on it called 'Play Input Sound'. Would it be easy to add this to the fixed bar recorder patch? At the moment, i have to mute my guitar track before i press record on the fixed bar recorder, otherwise the volume doubles while I'm recording the loop (obviously the audio is being routed to the patch while recording) and then goes back to normal when looping. Ideally i'd like the recorder to be silent while recording.
I look at these synced patches, with all their little maths modules and such, and i can;t make head nor tail of them. So any help wuold be greatly appreciated.
Thanks!!
Fixed bar recorder (sync) request
captaingoatboy
captaingoatboy
thanks, i think.
if i run into problems i take it i can ask questions without my eyes and brain being commented on?
it was cold, and it rained, and so i felt like an actor.
