Notation software?
Kaspar
Unread post by Kaspar » 29 Jun 2008, 11:17
Hi!
Does anybody know a notation software that:
1) Is low-price/free
2) Handles polymetric notation
3) Can notate multiple tempi on parallel staves
4) Option to omit time signature and bar lines
5) Tuplets such as 4:3 and 8:6
6) Has MIDI output
So far I've found out these:
LilyPond - the closest notation output-wise, best engraving output, but is difficult to use:
http://lilypond.org/web/index
LilyPondTool - can be of help to input LilyPond syntax:
http://lilypondtool.organum.hu/85.0.... ... kPid%5D=84
Denemo - GUI for LilyPond, sort of:
http://www.denemo.org/?q=node/3
Canorus - quite raw at this stage, but developing:
https://canorus.berlios.de/wiki/index.php/Main_Page
MuseScore - doesn't have the polymetric features that I'm after, but has the most mature interface:
http://mscore.sourceforge.net/en/idx.php
MagicScore - about same description as the previous:
http://www.musicaleditor.com/
So, how do you this kind of notation, that can be consitered as "contemporary"?
Is the parchment the only way? :)
Kaspar
Unread post by Kaspar » 30 Jun 2008, 22:20
A worthy addition:
PWGL
http://www2.siba.fi/PWGL/enp.html
Bit more than just a notation program.
Have to test it though...
stanlea
Unread post by stanlea » 16 Jul 2008, 07:40
Does Lilypond have midi output ?
You know my name (look up the number)
Kaspar
Unread post by Kaspar » 16 Jul 2008, 09:25
stanlea wrote:Does Lilypond have midi output ?
Yes, you can convert the result to a MIDI file:
http://lilypond.org/doc/v2.10/Documenta ... IDI-output
Kaspar
Unread post by Kaspar » 16 Jul 2008, 20:15
maxdis wrote:Melody Assistant
or
Harmony Assistant
http://www.myriad-online.com
Thanks for the suggestion.
Can it handle the points I listed above?
Users browsing this forum: No registered users and 406 guests
