Is it possible to delete all files in a specific folder with the 'Shell Command' Module ?
If Yes, How ?
Shell Command
- senso
enter the command
in the command line?
Code: Select all
del C:"my folder"*.* /QOlivier Sens
Personally, I create .CMD files that I call from the shell module, but that's just me. As long as there's only one command needed, you should be able to do everything that's possible from the command line in Windows from within Usine also.
Try the del command with <drive><path><filename.extension>; eg
or
The /F and /Q switches forces deletion of read-only files, and "quiet mode" (no prompting for confirmation using global wildcard *.*) respectively.
I'm not totally sure whether the switches may differ between languages (but I don't think so). In case you have a non-English Window installation, have a look at the options for the del command by entering cmd in the Start/Run dialog box, and at the prompt in the command window that should pop up, type "del /?" which lists the available switches.
[EDIT]: Senso beat me to it, aaarrgghhh!!!
Code: Select all
"del C:tempaudio*.*".Code: Select all
"del C:tempaudio*.* /F /Q".I'm not totally sure whether the switches may differ between languages (but I don't think so). In case you have a non-English Window installation, have a look at the options for the del command by entering cmd in the Start/Run dialog box, and at the prompt in the command window that should pop up, type "del /?" which lists the available switches.
- cmodica
OK. Thank you very much, but that is what i tried to do, but nothing happens !!
This is the code that i wrote in the command line of Shell Module
But nothing is deleting ....code :
del D:Audio ProdUsine RecordEssai 1*.* /Q
- senso
don't forget quotes (") especially if your path contains space characters.
try
try
TO BSORK: the DOS language is universal and the syntax is is the same whatever the country.code :
del D:"Audio Prod""Usine Record""Essai 1"*.* /Q
- cmodica
It is OK if i create a '.cmd' file, but it don't delete the file if i write the command in the command line of the shell module.
So i made a 'del.cmd' file with the code :
and i call the del.cmd in the command line of the shell moduledel "D:Audio ProdUsine RecordEssai 1*.*" /Q
Like that everythink is ok.D:Audio Prodcommanddel.cmd
