Video of a Wiimote controlling Usine
A video of senso playing with a Wiimote to controlling Usine
http://www.dailymotion.com/sensomusic/v ... e_creation
The Wiimote module will be included in the next release and the patch in add-ons
really , really great !
what solution do you use ..? bluetooth or 2 leds to capt the signal...?
humm , time to buy one...
best price found here in France 36 euros , amazon
only by bluetooth.
It gives less precision but it's simpler ...
Excellent, Mr. Senso!
The Wiimote can also be used un IR mode in Usine but you have to create a small IR led hardware.
magnificient!!!!
q: blue soleil or another versatile bluetooth manager will be the only background app?
q: can we now have wiimote action without virtual midi drivers (glovepie replacement). would be the first vst capable solution (well.. after deckadance, but deckadance does not output midi)
yes the module is totally included in Usine (don't need glovepie or other stuffs)!
this sounds great !. will this new feature also be in the free version ? thanks
yes, in the actual 3.68 free version.
Seems that my wiimote isn't reconized ...
Should I do something ? or should it works like that
I know there is sometime a pb with the wiimote in vista.
but works fine with xp.
to start the recognition procedure press the 1 & 2 buttons at the same time.
depending of your bluetooth key , but i've resolve it with this little appz :
http://www.2style-graphics.de/wiiconnec ... ct-0.5.rar
maybe can solve your problems too..?
here the forum link :
http://www.wiimoteproject.com/wiimote-a ... e-test-it/
thanks
After several rebooting, here I am :
I see the wii in windows (as game HID I think)
I saw the wii buttuns in Usine for a few seconds and the lights were still flashing and now I don't see it in Usine and I only get the lights flashing for several seconds after I press 1 and 2 ... (so if I understand what you said only means the wii is trying to get reconized
I activated the wii as a game and pointer controller (or something like that) ? should I untick that ?
(still using XP so it should works)
Sorry again but do I need bluesoleil ? or anysoftware ?
Users browsing this forum: No registered users and 457 guests
