All Notes Off
Unread post by bsork » 26 May 2006, 09:05
Hello Olivier, I have problems with "hanging" notes.
Would it be possible to have All Notes Off messages sent when the Audio engine stops? Preferably also when synchro stops, but I guess I can program that myself. Another possible variety would be to add a "panic" button to kill hanging notes.
Unread post by senso » 26 May 2006, 11:48
I'm thinking about it.
Where should I send the all note off?
1- from the midi player output?
2- to all external midi outputs (to expanders connected)?
3- both?
The first solution can be implemented easily when the synchro stops.
The next version of Usine will come soon with a lot of improvements in the midiplayer: record/save recorded file/ more synchro accurate, etc.
Probably next monday?
Unread post by bsork » 26 May 2006, 12:44
Hey - you're working fast!
I would prefer both, maybe as a separate module for the external outputs. For my use it could be hardcoded to every output, but if someone uses some old synth, they might prefer to have a choice, since I can well remember the strange noises that some instruments gave off if they where still emitting a sound when the All Notes Off message came...
lalo
Unread post by lalo » 26 May 2006, 16:10
senso wrote:The next version of Usine will come soon with a lot of improvements in the midiplayer: record/save recorded file/ more synchro accurate, etc.
oh yeah :)
Users browsing this forum: No registered users and 116 guests
