other small corrections [3.66d]
Announcements
Unread post by senso » 17 Jun 2008, 21:08
version [3.66d]
fixed bugs
- the list box module doesn't work in the interface builder
- the setup options are not saved in the VST version
sorry for all the last minute updates...
[3.66c]
Important
This version solves the aux send glitch problems
some details [3.66b]
improvements
- mouse position outlet in XY panel and surround panner
fixed bugs
- small details when resizing windows, especially in the Interface builder and the script.
- manual updates and corrections
new version [3.66]
Major release
improvements
- the interface builder WYSWYG
- the interface builder window can now contains other interface window (like containers).
- new track mixer output design
- 4 aux buses (Pro version only)
- new PianoRoll design, more ergonomic.
- now you can specify a range for midilearns on faders to reduce their range.
- more design options in the Separator module. Can now be used as a Panel.
- grain sampler speed mode up to 16 bars
- the loading of big interface builder is 2 times faster and lighter in memory.
- new option in the data random module to repeat the last values.
- new step, sequenced switches, and sequenced lines modules design.
fixed bugs
- display value bug in vertical faders
- get array size module: max size now equals 512
- other various array bugs when size = 0
- more generally, in array modules the Size = 0 is now allowed
- the data selector is now compatible with midi flows.
Compatibility notes (pro version only)
with the new aux buses management (4 aux buses on the pro version) some compatibility problems can appear:
- in the track mixer-input in-selector when conductor recall
- in additional audio input module
- in the track mixer-output module
Stefan
Unread post by Stefan » 17 Jun 2008, 21:50
Hi senso,
thank you for all the last minute updates! :)
runagate
Unread post by runagate » 17 Jun 2008, 21:52
Sorry? You = amazing. Thanks. This should be a great week in Usinery.
I can't wait to make crazy sounds. I happen to be designing a whole new live set, so I'm ecstatic.
martignasse
Unread post by martignasse » 17 Jun 2008, 23:22
WOW
i just can say
FAST and FURIOUS ;-)
Juanjo
Unread post by Juanjo » 18 Jun 2008, 12:52
Great stuff as usual and great reaction time on the updates ;)
martignasse
Unread post by martignasse » 18 Jun 2008, 14:34
fixed bugs
just one thing, it's seems like for a big list, there is a bigger and bigger offset of the mouse selection(between where we click and the line selected).
especially noticeable at the end of the list.
But it's usuable.
