Important Corrections [3.66c]
Announcements
Unread post by senso » 17 Jun 2008, 09:46
[3.66c]
Important
This version solves the aux send glitch problems
some details [3.66b]
improvements
- mouse position outlet in XY panel and surround panner
fixed bugs
- small details when resizing windows, especially in the Interface builder and the script.
- manual updates and corrections
new version [3.66]
Major release
improvements
- the interface builder WYSWYG
- the interface builder window can now contains other interface window (like containers).
- new track mixer output design
- 4 aux buses (Pro version only)
- new PianoRoll design, more ergonomic.
- now you can specify a range for midilearns on faders to reduce their range.
- more design options in the Separator module. Can now be used as a Panel.
- grain sampler speed mode up to 16 bars
- the loading of big interface builder is 2 times faster and lighter in memory.
- new option in the data random module to repeat the last values.
- new step, sequenced switches, and sequenced lines modules design.
fixed bugs
- display value bug in vertical faders
- get array size module: max size now equals 512
- other various array bugs when size = 0
- more generally, in array modules the Size = 0 is now allowed
- the data selector is now compatible with midi flows.
Compatibility notes (pro version only)
with the new aux buses management (4 aux buses on the pro version) some compatibility problems can appear:
- in the track mixer-input in-selector when conductor recall
- in additional audio input module
- in the track mixer-output module
runagate
Unread post by runagate » 17 Jun 2008, 16:30
Wicked. Thanks, Olivier.
Users browsing this forum: No registered users and 176 guests
