Is there a 'master patch'?
Stefan
Unread post by Stefan » 14 Jun 2008, 10:53
I just want to be sure: Is there a single master patch in usine? I can´t find it... :)
I am aware of the master section with the INs and OUTs of the 10 tracks, but for example: if I want to put a limiter on the sum of all tracks (to avoid the detonation of my speakers), I have to route this myself? Or is there 'one patch to bind them all'?
Best regards,
Stefan
btw: yesterday I played for the first time with my new FCB1010... and I became a god in the heaven of sound that Usine delivers... :D
I sure have fun! Thanks again for this great application!
Unread post by senso » 14 Jun 2008, 12:58
unfortunately there is no 'Master-Master patch' in Usine but several 'Master patches' associated to each virtual In/out.
If you use 5 virtual audio outputs you'll need 5 limiter patches.
Stefan
Unread post by Stefan » 14 Jun 2008, 15:33
Ah, that´s ok... makes sense, too.
Thanks for the info!
