Plugins DX ?
Plaf
Unread post by Plaf » 06 Jun 2008, 01:46
I'm a new user of Usine but it looks this soft doesn't work with dx plugins (if I don't mistake).
Is it complicated to implement it ?
Did you already think about it ?
That's because I have many interestings plugins dx and it looks too bad fot me not to use them !
PS: I'm a new user but I like Usine very much...
Unread post by senso » 06 Jun 2008, 12:42
it's not so easy to add dx compatibilty
did you a dx --> vst wrapper?
it's the easiest solution
Plaf
Unread post by Plaf » 06 Jun 2008, 13:02
I don't know what it is.
It's solution to use dx plugins, to transform them ?
It's a solution inside Usine or from anotherwhere ?
Plaf
Unread post by Plaf » 06 Jun 2008, 14:03
I've just try to find something about it on the net but it looks like this : vst wrapper--> dx...
Unread post by nay-seven » 06 Jun 2008, 15:59
you can check this one :
FFX-4 (Freeware)
http://www.vb-audio.com/
Plaf
Unread post by Plaf » 12 Jun 2008, 23:57
Thank you very much, I didn't know it.
But I wanted to use them with midi learn and it looks impossible because the controls don't appear but FFX-4's controls !
Is it possible by a way I didn't find ?
Vincent
Unread post by Vincent » 16 Jun 2008, 02:38
Well, plaf, I don't use DX plugins and I did not know about DX --> VST wrappers, so maybe should I go out...
But can you connect controls like faders or knobs to a DX --> VST module?
If yes, you now know how to do a midi learn on them ;)
I think it's generally more efficient not to use the plugins interface but only some controls from "browser/modules/interface design". Personnaly, I never see my plugins, except at the very beginning of the patching work.
vincent michel
composer & novelist
Plaf
Unread post by Plaf » 28 Jun 2008, 01:09
I'm not sure to understand what you say but...
I don't want to SEE the plugins, I just want to control them (some parameters).
