Usine VST GUI has a hard time in Peavey's ReValver 3
Newbie Brad
Unread post by Newbie Brad » 09 May 2008, 00:06
I would like to see if I can nest Usine inside of R3 instead of what I've done previously, which is to nest R3 inside Usine. At the present Usine VST seems it can be loaded, but its GUI can't be displayed. I have notified Michael at (Alien Connections) Peavey. NB
PS R3 has a module called VST Host that can load a VST and the module can be put anywhere in the R3's "rack" a bit like Reason with a VST module added.
Unread post by senso » 09 May 2008, 10:20
i'll check
LevraiBernardo
Unread post by LevraiBernardo » 10 May 2008, 09:10
I use Revalver (version 2) in Usine, and it works fine. I think it is much more easy to configure and more stable this way than using Usine VST in Rvalver's host.
(You can use 2 instances of revalver with half preset in each one, and the patch you wanted to load in usine VST between them, and much more...)
Newbie Brad
Unread post by Newbie Brad » 16 May 2008, 23:48
Please see if using Usine VST inside ReValver 3's VST Host module can be improved for the GUI. That's a signal path I'd like to try, though I also like the other way. NB
Unread post by senso » 18 May 2008, 09:21
problem solved,
next release
Newbie Brad
Unread post by Newbie Brad » 18 May 2008, 17:44
Nice, thank you! PS I am using Usine VST with Reaper and Reaper's NinJam plugin to stream live duet performances to 2 festivals this month. Thank you for Usine VST! Best, NB
