How is it possible to toggle between 'Live Mode' and 'Sequencer Mode' with only one "MidiLearned" switch?
I've tryed many patches and they all work the same way:
- From Sequencer Mode to Live Mode, it works fine, but the switch stays ON (!)
- From Live Mode to Sequencer Mode (even with the switch OFF), it does not work.
I've also tryed with User Curves and it works fine. But I need to be able to do it at any time with a single midi switch.
Thanks for your help!
CtrlF1 / CtrlF2
vincent michel
composer & novelist
composer & novelist
i need this for the fadein/out patch i've made
try :
swich to 1to 0 and 0to 1 ,
then 1to0 to pass if chang to seq inlet of dashboard
and 0to1 to pass if chang to live inlet of dashboard
switch visible in interface builder of course...
try :
That's it, Yan, the switch must be visible in the interface builder. You're right.
Except that I don't use it, since it's more disturbing than helpfull in live mode...
I'll find somthing else.
vincent michel
composer & novelist
composer & novelist
Users browsing this forum: No registered users and 25 guests
