Few suggestions:
bmoussay
Unread post by bmoussay » 24 Apr 2008, 13:03
Hi Olivier,
A few suggestions:
- in the piano roll the possibility to set the grid to triplets (or other nuplets), when entering notes with the mouse (maybe a fader "grid" we could set to 2, 3, 4, n, that would set the basic grid, an then as it is now the precision of the grid depending of the zoom factor).
- in the step or line modules the possibility like in faders to set the precision (integer ; ,x ; ,xx ; etc...). I've tried some workaround: step "values" out -> math "round" -> pass if changed -> step "values" in, but it doesn't work quite well.
- maybe also in the step and lines, the possibility to display a vertical grid (I mean display n horizontal lines as a guide to set values)
- in the "listbox buttons" (and maybe also other listbox modules) the possibility to set quantization.
What do you think?
Regards,
B.
Unread post by senso » 25 Apr 2008, 16:07
good suggestion, I'll try to implement them soon.
I'm still busy with the vst debug.....
franck
Unread post by franck » 25 Apr 2008, 19:29
Im agree with bmoussay, but not only for the piano roll module, for the piano roll sequencer too.
good work Olivier
franck
Unread post by senso » 25 Apr 2008, 21:57
in intern both (module and sequencer) are the same, so don't worry!
Users browsing this forum: No registered users and 118 guests
