More auxes..like 6?
lalo
Unread post by lalo » 17 May 2006, 09:51
hi,
would be very nice to have more aux busses..like 6
Unread post by senso » 17 May 2006, 10:31
I know that in some situations 2 aux is not enough.
The problem is that Aux busses can cost a lot of CPU Time.
I'm thinking about a way to create templates of tracks, depending on your project.
Stereo no aux
Stereo 2 aux
Stereo 4 aux
5.1 no aux
5.1 2 aux
8.0 no aux
If you are impatient, you can, also, create interesting routings using the tracks (1 to 16) as input with the mute, to chain patchs.
And to communicate between patchs you can use the "math/global variable" modules to send or receive sound. I use it in some complex situations.
lalo
Unread post by lalo » 17 May 2006, 10:38
the template idea is very good :)
..i'll investigate your workarounds...i'm still a newbie :)
thanx
