no sound from jamstix
JamminFool
Unread post by JamminFool » 11 Apr 2008, 01:02
hi olivier,
i just updated both usine (3.62) and jamstix (2.2.1) at the same time so i am not sure if it ever worked, but i am getting no sound from the jamstix vsti.
the transport runs in jamstix when i start the transport in usine, but there is no output.
for reference, this new version of jamstix works fine in XT2, Live 6 and Phrazor, so i thought i would pass this info on to you...
regards.
Unread post by senso » 11 Apr 2008, 10:17
the previous of jamstix version was working great but they change the way they receive cycle informations from the host...
If you assign the cycle length to, for example 16, jamstix runs but only one cycle...
Anyway, the problem is fixed, next release.
JamminFool
Unread post by JamminFool » 11 Apr 2008, 14:48
thank you.
yes, i wasn't able to easily test the previous version, so i wasn't sure...
in any event, i really appreciate your help.
best regards.
Users browsing this forum: No registered users and 248 guests
