Conductor automation
captaingoatboy
Unread post by captaingoatboy » 10 Apr 2008, 12:26
Hey!
I was wondering if there was a way to automate the conductor without having to know the SMPTE positon? I was hoping to do this with a piano roll on a spare track containing the midi notes for switching parts, sent out of Maple Midi cable, but I can't get it to work (probably my fault). Would it be possible to add a column to the normal conductor where you specify the number of bars or cycles alongside the SMPTE position? Alternatively is there an way easy way to implement this feature as it is?
Thanks!!
it was cold, and it rained, and so i felt like an actor.
Unread post by senso » 10 Apr 2008, 13:06
you can try the following tip:
1) create your snap shots in the conductor
3) add a interface control/usine panels/conductor module
2) add a pianoroll module
3) add Midi/miditools/midi get message.script
4) connect pianoroll- midi out -->> midi get message - in
5) connect midi get message - data1 -->> conductor - num
6) in the pianoroll add midi notes number 0,1,2,3 where you want,
now each time the pianoroll plays a midi note N it recalls the conductor N
3 modules and 2 wires!
it works
captaingoatboy
Unread post by captaingoatboy » 10 Apr 2008, 14:17
Get it on!! thanks Olivier, and thanks for the wonderful software. Keep it up!!
Kev
Users browsing this forum: No registered users and 35 guests
