Hi everybody,
I'd like to use several preset manager (I need more than 8 programs), so all I need to know is how to assign pgm changes 8 - 15 to the second preset manager, then pgm changes 16-23 to the trird preset manager, and so on.
Thanks a lot !
DC
How to control several preset manager
daviche
- senso
hello,
I've posted in the add-on section an example of patch to use PC from 0 to 31 to recall presets of 4 different preset managers.
Can be easily adapted to your purpose.
http://www.sensomusic.com/addons/index. ... 0,0,0,0,#3
Also I'll will change the preset manager module and include direct access to presets by a simple button. So it will be possible to make a direct midi learn on the preset very easily.
martignasse
hi bsork,
i had this problem too, the solution i found was to make the preset number to "-1" for all the "no active" preset manager module.
hope it help
hope it help
