pause switchon the grain sampler module
martignasse
Unread post by martignasse » 28 Feb 2008, 14:26
hi,
tried it yesterday and discovered the pause switch is inoperent, and not mentionned in the manual, is it normal ?
and in the same way, we should have a pause switch on the piano roll module two.
Unread post by senso » 28 Feb 2008, 17:17
thanks for feedbacks
the pause doesn't work in the grain sampler;
bug fixed.
I'll post an update.
I'll try to implement the pause in the pianoroll module soon.
