Is it possible to go Through the différent scene stored in the conductor without affect the volume, pan, aux send .... of the traks in the workspace ?
For example : I have 4 tracks and 5 scene in the conductor. When i go from scene 1 to scene 2, i change the audio processing in tracks 2 and 4 but i want to keep the actual volume, pan, aux send ... of each tracks. I use this in improvisation set, and the different set of the volume, pan, aux send ... parameters are never the same. So it is impossible to store then in conductor.
If the "not store in conductor" option is activate, they go in the default value and not stay in the last one use in the previous scene ?
Did i made a mistake, or it is not possible to do that ?
Thank you
Conductor and general remote
- senso
in that case, normally the controls shouldn't be affected by the recall.If the "not store in conductor" option is activate, they go in the default value and not stay in the last one use in the previous scene ?
(they stay in their current position)
I'll take a look.
- cmodica
I will try again this afternoon, perhap's i made a mistake ....
- cmodica
I have been trying with a new workspace and i think there is a problem or something that i doesn't understand ...
Even if "Not stored in conductor" is activate, the control go to the default set. For exemple the volume control of a track is set to -10db and when i call the next scene it go to the default value (O db) !!!!
- senso
I'll check it
- senso
fixed I'll post an update soon
