After successfully scanning for VST and VST3 plugins, they do not appear in the browser..
I close USINE, and when I open, nothing in the plugins folder.
What should I check?
VST plugins issue
did you point to the directory where your VST are installed ?
percuson
Actually all should be fine within Usine.
I don't know how experienced you are, so here is probably a stupid question:
Are your plugins 64-bit? because 32-bit will not work.
Did you also check, if they load in another program/DAW?
percuson
I am usually not working with plugins, but I sometimes had Plugins Usine didn't load. Just don't know if another DAW would.
In the Usine folder go to Config -> Plugins. There you find folders and .init files. In the folders there should be copies of the plugins. And the .init files you can read in any text editor. Probably you find some information there.
You could also just try with a freshly unzipped Usine version. Probably the quickest fix.
ClotildeLouise
- New member
Je pense que le problème pourrait résider dans la configuration du chemin d'accès des plugins VST. J'ai eu une expérience similaire avec une autre application audio, et réinitialiser le chemin d'accès au dossier des plugins a résolu le problème. Je vais vérifier cela et vous informer de mes résultats.
