Very long delay
Very long delay
Unread post by Gilsornette » 24 Jun 2026, 12:42
Is it possible to have delay longer than 5 minutes in Usine?
The modules seem to provide a max at 60000ms.
Thank you
Unread post by grego mondo » 24 Jun 2026, 14:20
Years ago I did something like that with Samplitude it used to have two different record-head and play-head.
I could start my set pressing rec, and 5 minute later I would press play ...
Maybe on that idea you can record and play later on
With 2 recorders.
max length set to whatever and when the time is over stop rec on recorder A, start play on recorder A & start rec on recorder B ...
Unread post by oli_lab » 24 Jun 2026, 14:46
audio delay is 1 minute max,
if you need more, just put 2 delays in series and you get 2 minutes.
you can use the digital delay from Oli_Lab (modulilab) that goes up to 4,55 minutes
but if the idea is to replay something 10 minutes later, a recorder is the way to go. You can record and save on the disk and read it later, it is safer in a live environement that a 10 minutes delay that will clear if you stop the audio engine.
Unread post by Gilsornette » 25 Jun 2026, 09:16
Thank you very much Olivar. I'll probably need more than 5mn so I'll try with 2 digital delays in serie and the option with the recorder. I'll decide what's the best for my use.
Have a nice day!
Unread post by oli_lab » 25 Jun 2026, 14:11
Here's an example to save audio files from a sampler.
filename record sampler.zip
the date will allows to sort the files by time of recording, so it will be easy to play them in order.
the name will allows to sort the files by names ! For example, I did use this kind of system with an hundred of kids this year, each one could record and retrieved is own sounds with the help of a RFDI card !
enjoy !
