Update 3.55 (Spectral Edition)
Intermediate release 3.55 (Spectral Edition)
Improvements
- new set of Spectral and FFT audio manipulation
See examples in the demo folder:
Spectral Gate
Spectral Expand/Compress
Spectral Analysis
Spectral Shift Frequency
Spectral Filter
Spectral Clip
- new set of array manipulation modules
- new Direct to Disk engine more efficient, with a new buffering system.
Fixed bugs
- keyboard conflicts with Battery3 plug-in
- next-previous doesn't work properly in loop mode of the sampler module
Usine VST version will arrive in march...
Improvements
Spectral Gate
Spectral Analysis
Spectral Filter
Spectral Clip
Fixed bugs
Wonderfull !!! I will try it, i am so exited to test the new FFT tools ....
Thank you
Thank you
Just downladed twicw but....the file seems broken! you know, when you try to decompress it, a pop up "pops up" saying it's damaged....
Ciao,
Goyya
Ciao,
Goyya
Yes, the archive is corrupt.
You know my name (look up the number)
yes zip files are corrupted.
I upload the 3.55b now.
Sorry...
Sorry...
Now the zip uncompresses well, but the Usine exe file crashes.
WOW!
I love this!
I love this!
Me too! No chrashes, and everything seems to be working ok.
...if only I understood anything of the FFT/Spectral stuff... Good that someone else does.
Thanks, Olivier!
Thanks, Olivier!
I insist : this version crashes on my PC, the app crashes, closes but a ghost process remains in my task manager. Could it be dual core related ?
Normally in this version there is no change in the audio engine, but only few modules added. But in computer domain we never know...I insist : this version crashes on my PC
Can you send me the log file?
OK but now it seems there's a problem with my config. Old versions also crash, so it's not the new version. So I'll post no more here, sorry for the thrills. Anyway, I'll send you the log.
good news for me, but not for you!
A reboot solved the problem. Probably a shared ddl with a program that had crashed.
multiphone
To busy to check the new version of usine.
But i'ts marvelous ! You develops much faster than I do music... i'ts fantastic.
I check that today.
Thanks for your job.
H.
I check that today.
H.
Users browsing this forum: Bing [Bot] and 42 guests
