Impossible to load Arturia Pigments 7 in Usine.
The VST is ok in other DAW but it is not appearing in the plugins list in Usine. I made a new plugins scan, but it isn't solve the problem.
I am on MAC OS 26.2
Can i expect a solution or it will not work in Usine ?
Thank you ?
Arturia Pigments is not loading
Hi Christophe,
On Windows, with the latest version of Pigment 7 and Usine Win 6.0.250506, it works, but the plugin requires you to disable the MIDI output of the controllers used. See below.
This may be a solution for opening Pigment on Mac?
However, it takes a long time to open and uses a huge amount of RAM on a single rack!
But on my computeur with Mac OS 26.2, with Usine 6.0.25.1117 Pigments doesn't appear in the plugins list. Not as a VST, not as a VST 3, not as an AU.
So impossible to load it ...
Users browsing this forum: No registered users and 44 guests
