Bug on midi ouptut
syonh
Bug on midi ouptut
Unread post by syonh » 27 Aug 2025, 14:30
I've made a workspace that modify the midi output of a controller.
All works fine but I've noticed that certain CCs are not received by my DAW, and any other.
It seems to appear on the following CCs : 38,98,99,100 & 101.
I've already tried to make a simple midi generator in Usine and sent it directly on the output, the problem remains.
On the midi ouptut, when using the concerned CCs, Usine seems to send the correct information, but when using a midi monitor, I don't see any information going out from Usine...
Does anyone has an idea ?
Thanks !
Unread post by oli_lab » 08 Sep 2025, 01:14
I think that those CC# 38,98,99,100 & 101 in you DAW that is receiving from Usine.
38 is data entry
98,99, 100 and 101 are for 14bit NRPN and RPN
so if you do send them, you DAW can only use them for that purpose and not as ordinary continuous messages.
https://www.presetpatch.com/midi-cc-list.aspx
https://www.recordingblogs.com/wiki/mid ... number-rpn
