Loading GM Drum midi file into USINE
Ariajazz
Hi all. I'm trying to built a Drum machine which will play different style patterns. I intend to use EZDRUMMER as the sound module and piano roll or grid to trigger the files. My question, how do I load midi pattern file either to the piano roll module or to the grid. The midi files are type 0.
- rlgsbt
1. when you create a piano roll, you have to choose the number of midifiles/pattern you want.
2.for each "num file", you can write, edit or import midi file
3. Then, you can choose your midi pattern wiith "midi file selection/num fil"
