The position gets remembered with the preset (which I'd rather it didn't) so it seems like Usine can control its position... (or maybe that's hidden in the vst chunk??) But there doesn't seem to be any place to specify or override it. I know it used to be possible to embed a vst window in a usine window. I miss that feature....
Anyway, I'd like my vsts to always open in the same position, regardless of where they were when the preset was saved. Is this possible? I do a lot of preset work on the desktop with the big monitor, and that can make the vsts open off-screen in my live setup.
THANKS!
-eric
Specify position of vst popup?
