how to get value for global array string
Unread post by woodslanding » 25 May 2025, 05:52
my guess of GetGlobalArrayString doesn't work.
(I'm using usine from last october while I wait for the authorisation for the new version, so let me know if this has been added since....)
Thanks!
Edit: talking about via script, btw....
Unread post by woodslanding » 01 Apr 2026, 20:15
here I am needing it again.... a search only turns up the crickets from my first request ;D
Workaround in progress. maybe I'll check back next year....
If this exists, it should be added to the manual.
Unread post by oli_lab » 01 Apr 2026, 21:22
Can you explain what exactly you want to achieve so I can provide you with a patch ?
Unread post by oli_lab » 10 Apr 2026, 11:00
Check this workspace :
set and get GA string.wkp
(114.17 KiB) Downloaded 25 times
what should be remember is :
- declare the GA with a unique name
- populate the GA with "set" modules
- get values with "get" modules
- be aware of the "pass if changed" switch inside the "get" modules
- avoid connecting anything to the GA declaration module, just leave it alone.
Usually, I put all the GA declaration modules in one same patch for code cleanliness
If you need multi-dimension arrays, you can explore putting an array inside a polyphonic subpatch
or use Json
