multidimensional arrays in scripts?
Unread post by woodslanding » 14 Apr 2025, 18:48
this syntax is from pascal forums:
var x: array [1..5, 1..9] of integer;
but usine complains about the comma.
Can we use multi-dimensional arrays? If so how?
And more broadly, what variant of pascal does usine actually employ??
THANKS!
-eric
Unread post by SylvainT » 17 Apr 2025, 08:06
Hi Eric,
We don't have multidimensional arrays in Usine. We talked many times about that, but never went through.
Actually, there's a solution if you really need it. A comma-text can be think as a multidimensional array, but you have to manipulation either string and data. There's an example in the French section of the forum, viewtopic.php?f=25&t=7318
Best
Unread post by senso » 17 Apr 2025, 15:43
another soluce is to use "old style" pascal:
Code: Select all
var x: array [1..5] of array [1..9] of integer
// and inside the code
  x[i][j] := i*j;
Unread post by woodslanding » 21 Apr 2025, 21:38
Thanks!
I am still curious what particular brand of pascal Usine uses....
I found a workaround that keeps my code more readable:
for i = 0 to max
for j = 0 to max
idx = //compute from i and j
do stuff with array[idx]
However, I am now wishing for dynamic arrays in my second dimension, where each array in the array of arrays was of variable length.
var x: array [1..8] of array[] of integer;
I'll see if Usine lets me do that....
Unread post by oli_lab » 23 Apr 2025, 13:53
If you want variable size array, the best should be to use vectors en C++, and make a user module.
or a simpler way, use polyphony and an array within a sub-array ?
if the process is too heavy on the CPU, you can also use the "procedure" method.
arrays within arrays matrix.wkp
(676.35 KiB) Downloaded 895 times
Unread post by senso » 24 Apr 2025, 11:43
woodslanding wrote:
21 Apr 2025, 21:38
Sure it will work.
Users browsing this forum: No registered users and 28 guests
