Hi there
i don't manage to get my enttec opendmx into the dmx devices in the soft. it is as if nothing was plugged.
i am using the HH5 verion but also tried on the 6 and the 3
my drivers are up to date and i didn't met any issues with freestyler or qlc+
i don't know what to do, is there something more that i could try?
thx!!!
struggling with dmx devices pannel
- senso
on macOS, see the manual
https://www.brainmodular.com/manuals/hh ... sine/light
But on Mac OSX you'll probably have installation troubles with DMXUSB PRO devices. It's generally caused by FTDI drivers conflicts. So in this case you can try the utility app free FTDI Driver Control 1.0.3 to disable the built-in FTDI driver.
