Would it be possible to add the loop mode in the grid module ?
thanks.
S.
GRID MODULE loop mode
What do you mean by loop mode. The sections can already be set in loop mode, as the main grid. BTW, it is the default mode.
I guess you're referring to the grid module.
in that case the grid module needs an extra array input to set the loop mode.
while waiting for it you still can use the goto section and some external logic like the oli_lab seq GRAFCET
actually, grid module should be as versatile as the main grid !
great idea !
great idea !
"loop mode" on the usine-grid-module will be implemented in the next major version.
