Sampler Rec > circular buffer & max rec time
Unread post by rlgsbt » 13 Nov 2024, 16:25
In the Sampler Rec module configured as "circular buffer", it's not possible to change the "max rec time" in real time. If I patch a fader, I can reduce the buffer size, but then, it's impossible to increase it anymore.
Then, to setup the max rec time, you have to stop the audio engine, configure the sampler as "overdub", re-open the audio engine, change the module as "circular buffer"...
Is it a bug ? something to improve or I don't understand the way to use it ?
here is a demo rack:
Sampler Rec - circular buffer & max rec time.rack
thanks
