trouble with callback on matrix input
Unread post by woodslanding » 02 Nov 2024, 19:39
I have a script that aims to display matrix data in columns. It works fine for the text of the cells, but I recently tried to use it to reorder the cells values, and I'm having trouble with the array ins and outs.
Basically the output array only changes if the first item in the input array changes. I don't know why.. It sets the output array correctly for all items, but only when the first value in the input array has changed.
Code: Select all
// read matrix data newspaper style in columns
//e moon Nov 2022
const FAVTAG = '-';
var rowsIN, colsIN,ctIN,valsIN : Tparameter;
var ctOUT,dispCtOUT,valsOUT: Tparameter;
var gTextin, gTextOut, gDisplayText : TstringList;
var row, col : integer;
// Globally enable/disable logging///////////////////////////////////////
const DTAG = 'matrix Sw> ';
const DBUG_ON = TRUE;
procedure debug(s: string); begin if DBUG_ON then strace(DTAG + s); end;
procedure iDebug(s: string; num : integer); begin debug(s + '= ' + intToStr(num)); end;
procedure fDebug(s: string; num : single); begin debug(s + '= ' + floatToStr(num)); end;
// Always log, whether debug is on or not.
procedure Error(s: string); begin strace('ERROR-' + DTAG + s); end;
procedure fError(s: string; num : single); begin strace('ERROR-' + DTAG + s + '= ' + floatToStr(num)); end;
procedure init;
begin
    colsIN := CreateParam('col ct',ptDatafield,pioInput);
    rowsIN := CreateParam('row ct',ptDatafield,pioInput);
    ctIN := CreateParam('ctext',ptTextField,pioInput);
    valsIN := CreateParam('values',ptArray,pioInput);
    ctOUT := CreateParam('ct out',ptTextField,pioOutput);
    dispCtOUT := CreateParam('display ct',ptTextField,pioOutput);
    valsOUT := CreateParam('values out',ptArray, pioOutput);
    ModuleColor($FF8E44AD);
    gTextin.create; gTextOut.create; gDisplayText.create;
end;
// destroy
procedure Destroy; begin gTextIn.free; gTextOut.free; gDisplayText.free; end;
procedure Callback(n:integer);
var i,j,len: integer;
var val: float;
var text,displayT: string;
var options: TReplaceFlags;
VAR values : ARRAY OF float;
begin
    //setArrayLength(values, 0);
    //if n = valsIN then
    //begin
        len := valsIN.Length;
        valsOUT.Length(len);
        debug('vals in changed');
        j := 0;
        for col := 0 to (colsIN.asInteger - 1) do
        begin
            for row := 0 to (rowsIN.asInteger - 1) do
            begin
                i := (colsIN.asInteger * row) + col;
                valsOUT.asArray(j,valsIN.asArray(i));
                //values[j] := valsIN.asArray(i));
                //iDebug('setting output array position',j);
                //iDebug('to value',i);
                j := j + 1;
            end;
        end;
        gTextIn.clear; gTextOut.clear; gDisplayText.clear;
        gTextIn.setCommaText(ctIN.asString);
        options := [];
        begin
            begin
                i := (rowsIN.asInteger * col) + row;
                if i >= gTextIn.count then text := '' else text := gTextIn.getStrings(i);
                gTextOut.add(text);
                //trim leading '-' from names for display
                if text.startsWith(FAVTAG) then displayT := StringReplace(text, FAVTAG,'', options) else displayT := text;
                gDisplayText.add(displayT);
                j := j + 1;
            end;
        end;
        ctOUT.asString(gTextOut.GetCommatext);
        dispCtOUT.asString(gDisplayText.GetCommatext);
    //end;
end;
-eric
Unread post by woodslanding » 02 Nov 2024, 19:54
here's my test patch:
MatrixSwitchTestAgain.pat
(23.63 KiB) Downloaded 760 times
Again, if I change the value of the first cell, all arrayOUT values update correctly. But even though the callback method always gets called, it only works when the first arrayIN value changes.
MatrixSwitchTest.pat
(18.29 KiB) Downloaded 458 times
Unread post by SylvainT » 06 Nov 2024, 22:36
On my end, text doesn't react, but matrix input works as expected. 😉
Sorry, i haven't found time to dive into your script too much.
Unread post by oli_lab » 07 Nov 2024, 00:09
I tried to understand your patch, and I re-did it with modules from HH6
Hope it helps
combine string and data.pat
(41.84 KiB) Downloaded 971 times
Unread post by woodslanding » 07 Nov 2024, 16:46
Well, I re-wrote the script so it doesn't need to send an Array out. I still don't understand why it's not working, but I guess I don't need to know, for now.
