I'm using Spat Revolution with Usine.
Could you tell me if works on mac and pc.
Do you have any experience with Spat Revolution and Usine with PC ?
I'm using both softwares with an old macpro 2012. it works fine but it's heavy !
I was wondering if there is no problem to use Usine with its own inputs and outputs with the same sound card (RME) than the output of Spat Revolution on PC.
With apple, no problem. No conflict between the two software. with windows, never tried ..
Thanks a lot !
JF
Usine + Spat Revolution Does it work on Mac and PC ?
If Spat Rev is working well on PC, there is no reason to have any conflict with Usine.
Users browsing this forum: No registered users and 34 guests
