Grid scrolling
Grid scrolling
Could it be possible to have an option "grid auto scrolling" (mode défilement) with the cursor that stays in the middle , instead of going to the right side?
In live conditions I'm always obliged to move the grid to the left to be able see the following sections, what is essential for me.
I hope it's clear...
There already is a scrolling function in the grid.
Maybe, the simplest solution would be to keep the current section in the middle of the grid and not on the right.
Visual continuous scrolling could be unefficient as it would affect the graphic engine of Usine, and not really usefull.
Let's have a look
Let's have a look
Hello Sylvain,
I think I was not clear. I was not asking for a scrolling function, I know there is one, but only that the "mode défilement" (what I called grid auto scrolling) has an option
that allowes the current section to stay in the middle , not on the right. What you are proposing, if I well understand:-)
That would be fine!
Thank you!
That would be fine!
Thank you!
hello Sylvain,
did you have a look for the centered grid scroll ?
(keeping the current section in the middle of the grid, and not on the right...)
a new guy will use the grid for my shows, it's a long learning to know what will happen next for about 70 sections - so it's really usefull to see it! (less stressss...)
thanks
Hughes
thanks
Hughes
Hi Hugues,
This may help :
Cheers !
This may help :
Cheers !
I often use OSC from Usine to my iphone to send the name of the current section, next one and the previous one if needed. It works fine, there is only these infos on the screen and it is easy to read. I use TouchOSC on my phone for that.hello Sylvain,
thanks
Hughes
I hope it could help.
@Brainmodular team: thank you very much for modifying the scroll of the grid!
Could it be possible that we have an option to choose on which section the "repositionning" of the cursor is done? In some cases, the last one
of the grid is too late for me , I need to know what are the next sections (at least one or two).
