Do someone achieve to run kiosk mode with a mac? If so, what is the configuration you're using?
It works perfectly on pc but I need to use a mac (not a recent one) for an installation and , for now, it doesn't work.
Thank you
Kiosk Mode
normally you can use the same configuration file (override-seteup.ini) for mac or pc except ASIO specification which is pc only.
Ok, thank you. I'll have to try and check again.
Users browsing this forum: No registered users and 35 guests
